Extended bronco
agavelouis
The Champ
Bronco Info: 1994 5.0 Bronco. Solo Motorsports all the way around
Re: Extended bronco
Post by agavelouis »
We go to Mexico a few times a year. That being said the guys in my group have buggies or trucks capable of higher speeds in the rough stuff. I've got about 35k in the bronco now and thought well what's next. I have Patton racing going to do the motor soon. I still feel I'm not getting the ride I should out of the bronco. I've had the shocks off 3-4 times now and have changed the valving. Bilstien doesn't offer a tuning session like the shock manufacturing company's. I've never had a vehicle of this caliber before so I'm a little unsure of just how it should preform. It rides like shit in the little chatter until I air down to about 10-14 psi I'm running grabber tires that are D rated which could have something todo with it. So I'm reaching for more. I do have a little at home still so I don't really want to take everything inside the cab just yet. Example four link. I don't really have a budget so I guess I'm just looking for alternatives besides buying a luxury per runner. No lotto money yet or becoming an Indian. Lol
Judging by the handling issues you say you are having, wheelbase is not going to fix it.
Chatter being helped by low tire psi is shock setup for sure. Sounds like wayyyy too much initial valving. You said you have Bilsteins, which ones? I'm new here, and haven't seen your Bronco yet.
Our full built prerunner Bronco is standard wheelbase + - an inch. It is 4 linked with a coil-over and bypass + bumpstop at each corner. It has preran Mexico 4-6 times a year since 2000 when it was completed. It will take every inch of the Baja 1000 course with ease, but the San Felipe whoops are about a 45-50mph venture even with 3 link rear. They are deep, far apart and shitty. If you are still leaf sprung in the back stretching the Bronc isn't going net you much at all. If you are linked, then stretching will help a little.
Re: Extended bronco
The truck doesn't have to go to Bilstein to be tuned. Lots of guys in the socal area can tune those shocks. DC Shock Services & Mirage Racing are two off the top of my head. Paying for pro tuning is more than worth it. The difference between a slow unsafe truck and a fast prerunner is just a few shims in a shock.
Drew
Bronco Info: Just picked up a 95 bronco stock. Ready to make it go fast....lol
Re: Extended bronco
Post by Drew »
I've had them off several times. And taken them to Bilstien for the valving. First time the inside of the shocks where full of foreign material. Was gritty like sand. It's got four tube bypass up front with a coil and a bump. Four over beams. Bilstien had the coil overs fully valve. I've had them take all the valving out. And I've been playing with spring rates. Currently they are 350/500 and has helped. I've never had a vehicle with this much suspension. So knowing were it should be or how it should preform no idea. I drive pretty aggressive for having this much suspension it should ride like a marshmallow.
Drew
Re: Extended bronco
Post by Drew »
Here is some pics of the fluid not good. Found a shredder valve buried in the valving. Image
Drew
Re: Extended bronco
Post by Drew »
Drew
Re: Extended bronco
Post by Drew »
Re: Extended bronco
Wow, that's pretty ugly. Who did the shocks last time?
Drew
Re: Extended bronco
Post by Drew »
Lol drove to Bilstien three times. I need to take them apart to check them again.
Drew
Re: Extended bronco
Post by Drew »
philofab wrote:The truck doesn't have to go to Bilstein to be tuned. Lots of guys in the socal area can tune those shocks. DC Shock Services & Mirage Racing are two off the top of my head. Paying for pro tuning is more than worth it. The difference between a slow unsafe truck and a fast prerunner is just a few shims in a shock.
I need to see who can take the time to help. If they do do a tuning session I'm in.
Drew
Re: Extended bronco
Post by Drew »
Had I known the Bilstien didn't offer any tuning help I would have gone a different way. The only reason I went Bilstien was because that's who South West had suggested to go with.
Re: Extended bronco
Drew, I'm with Philo.....head to Mirage in San Diego or Shockseals in San Dimas.......you don't have to go directly to Bilstein for tuning.
Drew
Re: Extended bronco
Post by Drew »
Will do. I'll have to wait till Patton finishes the motor next month.
agavelouis
The Champ
Re: Extended bronco
YIKES! Those look gnarly inside.
My opinion is that a shock is only as good as you make it. In all of our race cars, testing is mandatory. Between 2008-2010 in my Trophylite we raced maybe a total of 1800 miles. I probably put another 800-1000 of hard 100% all out testing on my shocks and components to make sure they were up to snuff. From 2008-2010 we won 3 championships and over 15 races due the fact that nobody could keep up in the rough. We had the same Fox shocks that everyone else had, but we chose to do all of our own valving and spring rates which meant a lot of time in the desert.
Bilsteins are tuneable, and can work just fine but they just are not as popular. Kritter can do them up (ShockSeals) and you will be set. I would really like to see what was coming apart inside those bad boys though, might be what your issue has been for a while.
Re: Extended bronco
Down South Motorsports is a great shock tuner also. Lets get back to extended Broncos though!
drewbee88
Re: Extended bronco
Post by drewbee88 »
Travisfab wrote:Down South Motorsports is a great shock tuner also. Lets get back to extended Broncos though!
Exactly where's the pics of yours??? :-D
Re: Extended bronco
Re: Extended bronco
Any updates........
alpinejd3
Re: Extended bronco
Post by alpinejd3 »
Any updates on this old thread?
1Hondalover
Re: Extended bronco
Post by 1Hondalover »
Well not quite an update but in the same realm.
Can anyone tell me how these old split window Supercabs are put together? Is it a single piece of glass with the outer body piece over the top making it look like two?
Or is it two separate pieces of glass?
F150 Supercab.JPG (64.18 KiB) Viewed 1000 times
Re: Extended bronco
I'd love to know this too. I've always thought they were an outer piece that just made the same old window look like 2, but I've never gotten a close up look at one to verify.
