Raptor live valve shocks
- Bronco Info: 96 bronco xl 5.0 5 speed
Does anyone know how the new live valve raptor shocks are controlled ? Is it just a matter of voltage or resistance. The non live valve shocks are getting harder to find and I was curious if maybe you could just wire them up to a switch or resistor .
- Bronco Info: 1985 Bronco Victorian 2 tone blue stock at the moment
Re: Raptor live valve shocks
Yes, as current is applied to the coil the valve opens allowing fluid to flow with less restriction. I am currently working on something to make the adjustment manual. Unfortunately with the livewire system inactive the shocks are too firm to be useable.
