Hello All-
Anyone know of a stock application or aftermarket 8-rib serpentine crank pulley that fits the 5.8/351??
Thx-
Matt
8-Rib Crank Pulley on 351/5.8??
Re: 8-Rib Crank Pulley on 351/5.8??
Good question
Check the serp setup for the ambulances with two alternators, and check the diesel setups with two alternators. Theoretically they both need 8 ribs.
Of course you will need several pulleys to do a conversion.
Well everything minus the crank is just super simple swap.
