Gen 2 Raptor Coilovers on Bronco?
- Bronco Info: 1993 Bronco - 6in lift, solo radius arms. Want to buy a coilover conversion soon.
Hey guys so I ended up buying a full set of Gen 2 Raptor takeoff shocks/coilovers off ebay for $650. I really only needed the rears for my 1993 Bronco but now it's got me thinking about a use for the front coilovers. What are yalls thoughts on potentially making a custom bucket to mount these in the front to replace the coil springs? Would it work?
Re: Gen 2 Raptor Coilovers on Bronco?
Hey get some angle iron and find out! I’ve thought the same thing but don’t like the idea of a single rate setup
Cut the coil bucket and install an F250 shock mount.
https://therangerstation.com/tech_libra ... ower.shtml
I don't think that F-250 shock mount would fit the coilover...
Shock doesn't have enough travel and the spring rate is too high for beams.
I found a guy who had them on the front of his brick nose. He said the ride was improved. I'm thinking of just giving it a try with these Gen 2 coilovers and seeing how it is. I'll definitely install some limit straps and look into some softer spring rates coils
- FB_IMG_1572925169903.jpg (60.47 KiB) Viewed 1293 times
