Spindle Studs
tactical328
Bronco Info: future broncozilla
Spindle Studs
Post by tactical328 »
Any reason that using grade 8 bolts instead of the spicer spindle studs is a bad idea? Having trouble finding the spicer 36326-1 locally.
Thanks pals.
300
Re: Spindle Studs
Post by 300 »
Should be fine, however they are likely to spin on you.
LvSteve
Re: Spindle Studs
Post by LvSteve »
Re: Spindle Studs
This is on an early bronco Dana 44 so I’ll say that first - I drill out the knuckle to 25/64ths and the bolt goes thru the knuckle. I think a 1/4” breaker bar with a deep 9/16” 6-point socket is a great way hold the bolt. Not sure if any of this will work on a TTB knuckle.
Spindle Studs
I did backing plates on my knuckles. After that I ran grade 8 bolts cause I didn't want to figure out longer studs. I think I just did a couple tack welds to hold them in place.
Haven't failed yet haha
tactical328
Re: Spindle Studs
ended up putting alloy steel hex cap screws in the back seems like itll work out ok.
