Has anyone reinforced their plastic door panels? Mine are super flimsy/flappy, to the point my drivers side mirror wobbles in the thin sheet metal.
I’m going to likely pull them off soon to check on my sticking drivers door handle, and a mystery rattling inside the passenger door, and throwing sound insulation in while it’s apart.
Bracing Door Panels
- Becks_Bronco
Bracing Door Panels
I hate these door panels with a passion. The shaky mirror is likely broken. It has 2 bolts on the outside and one on the inside of the door. The arm that goes across to the inside of the door usually breaks from normal use. The door latch might be either the door skin is cracked and allowing movement enough so the handle doesn’t get enough throw, or the handles pivot pin might have worn through the bracket (have had this happen)
- Becks_Bronco
Re: Bracing Door Panels
That's what i was thinking on the mirror just based on pictures of replacements online. If only i could find a setoff blinker mirrors for a reasonable price... lol.Tchajagos wrote:I hate these door panels with a passion. The shaky mirror is likely broken. It has 2 bolts on the outside and one on the inside of the door. The arm that goes across to the inside of the door usually breaks from normal use. The door latch might be either the door skin is cracked and allowing movement enough so the handle doesn’t get enough throw, or the handles pivot pin might have worn through the bracket (have had this happen)
I'll have to see what's up with the handle system once i open it. Some days its totally fine, other days i have to roll down the window and open it using the outside handle. It looks like Solo makes a brace if the door skin is starting to fail.
Will, I'm pretty sure I've got interior handles/mechanisms here in the garage if you find an issue. I know I've got the exterior handles for sure. Think I have the interiors too as I was considering grafting all onto my crew.
- Becks_Bronco
Awesome! I didn’t get around to digging I to the doors this weekend, but I’m going to try this weekend along with rear diff fluid and maybe the front.ChaseTruck754 wrote:Will, I'm pretty sure I've got interior handles/mechanisms here in the garage if you find an issue. I know I've got the exterior handles for sure. Think I have the interiors too as I was considering grafting all onto my crew.
