Smog Pump Bypass Belt
S00TLYFE
Bronco Info: None Anymore!
Post by S00TLYFE »
Just wanted to give you guys a heads up. This is an easy and cheap fix if you are looking to remove you smog pump or if yours happens to seize up when youre out on the trail. You can run NAPA P/N 060915 in the factory routing format (just pretend the smog pump doesnt exist) figured id share, its easy to throw in the back of your rig and could get you home.
