Having a heck of a time telling the parts dude what I need. I've so far got every got every front axle seal except the ones I need. What i am looking for is the seal that goes up against the back of the spindle.
You can see what I pulled off on the left, and what this round of the parts store run got me on the right.
Seems so easy!
Stub Axle Seal?
Re: Stub Axle Seal?
Looks like I need a total of 4 parts per side
Re: Stub Axle Seal?
Unless you have late '95 or '96 style seals. Then it's just one piece.
Re: Stub Axle Seal?
The part that's kinda accordion of sorts is a Motorcraft brs-79 is the part number -- kicker is though the other brands don't fit like the MC does--I am not sure the part for the plastic piece and the small square looking o-ring. If you come up with a 3 piece kit by chance please post that up.
Re: Stub Axle Seal?
Oops. Misread. Disregard my last post.
Re: Stub Axle Seal?
The seals come in a kit that includes the needle bearing in the spindle. You need one kit for each side.
DAN706527X
The slinger ring, or the big washer that presses on to the stub axle is:
DAN36364
Both are widely available on line and not very expensive, even though you may not need that needle bearing. I get mine from West Coast Differentials.
DAN706527X
DAN36364
Re: Stub Axle Seal?
I have the kit noted above if needed..... it will do both sides.
