Steering wheels!
- DirtyMexican
replace stock steering wheel?
how hard would it be to replace my stock steering wheel with something like a momo, grant, etc on a 1990 bronco?
Re: replace stock steering wheel?
Not hard at all if you are not using cruise control.DirtyMexican wrote:how hard would it be to replace my stock steering wheel with something like a momo, grant, etc on a 1990 bronco?
If you dig around, you can find options for cruise control. I know that Grant had a set up, or you can do like Steve did. He had a bracket made for his.gunit wrote:Not hard at all if you are not using cruise control.DirtyMexican wrote:how hard would it be to replace my stock steering wheel with something like a momo, grant, etc on a 1990 bronco?
Changing the steering wheel is a piece of cake.
This is what the cool kids use to keep cruise control.
- cruisebracket6.jpg (88.75 KiB) Viewed 1925 times
How about on air bag equiped trucks?
You're kind of screwed. I don't know that it would be worth replacing. I tend to like later model steering wheels as they are anyway. The only reason I replaced mine was because it was so skinny. Yours probably has a nice grip on it.
- DirtyMexican
my steering column broke on me after an incident and when i replaced the column it came with a really skinny wheel. i hate it. my old one was perfect but bent up now. that looks like a pretty bitchen set up Steve.
Tis' easy!
Grant hub using adapter for sparco wheel.
- Deleted Account
Cruise Control with a custom steering wheel.
Ok i know somone around here knows the place that make the button adapter to put the cruise buttons on a billit bracket.. I think steve posted it. but ill be damned if i can find it...
Mark Kiefer
Southwest Performance
858-449-2292
Pics
858-449-2292
Pics
Re: Cruise Control with a custom steering wheel.
mkiefer wrote:Ok i know somone around here knows the place that make the button adapter to put the cruise buttons on a billit bracket.. I think steve posted it. but ill be damned if i can find it...
It was a grant piece, no longer in production I think, but I have seen them on ebay from time to time Keifer.
- DirtFiend602
- Bronco Info: 86' go faster
There are quite a few still floating around... maybe ill buy a whole lot of them, I bet they'll be a coveted item soon...
The Grant stuff was ugly and I refused to pay the price for aftermarket crap. I used a replica bracket for a Saleen Mustang on mine. It uses factory switches (better than aftermarket). I'll see if I can find contact info for the guy that was making them.
Not my steering wheel....
- cruise-control-switch-bracket.jpg (75.54 KiB) Viewed 1881 times
- cruisebracket6.jpg (88.75 KiB) Viewed 1881 times
- BajaF250
- Bronco Info: 1982 Ford F250
Wow, that looks pretty darn good! Almost wish I had cruise control!SteveG wrote:The Grant stuff was ugly and I refused to pay the price for aftermarket crap. I used a replica bracket for a Saleen Mustang on mine. It uses factory switches (better than aftermarket). I'll see if I can find contact info for the guy that was making them.
It does look good. Nothing a guy with a plasma cutter & sander couldn't whip up if he had to!
The part where the switches fit are pockets and would require milling. The guy I got mine from is a machinist... the part has been long discontinued so he borrowed one and duplicated it. I don't know if he ever did more runs or not, but it was a really nice part.ChaseTruck754 wrote:It does look good. Nothing a guy with a plasma cutter & sander couldn't whip up if he had to!
Well if you have a mill that can work too. If you aren't using yours & you're cool with it - I could borrow it, convert it to a cad file & people can use that to have new ones laser cut or water jetted. Both of these methods are better than the plasma I mentioned before - I was just saying if one wanted to - he could with that stuff.
They are just momentary switches... and the clock spring is already there... just sayin.
It's super easy to put them on the dash too... if your one of those cool guys with a removable wheel.
If I'm not mistaken, they have different resistances. They all use the same wire through the steering column, so they have to send a different signal to make the cruise control respond appropriately.philofab wrote:They are just momentary switches... and the clock spring is already there... just sayin.
I was originally going to put them in the dash until I remembered about the Saleen Mustangs using the aftermarket bracket.
And yes, Tom, cruise control ROCKS!
SteveG wrote:If I'm not mistaken, they have different resistances. They all use the same wire through the steering column, so they have to send a different signal to make the cruise control respond appropriately.philofab wrote:They are just momentary switches... and the clock spring is already there... just sayin.
The older ones didn't....no biggie... just need $4 worth of resistors from Radio Shack.
- DirtFiend602
This. I'd buy one!
ChaseTruck754 wrote:Well if you have a mill that can work too. If you aren't using yours & you're cool with it - I could borrow it, convert it to a cad file & people can use that to have new ones laser cut or water jetted. Both of these methods are better than the plasma I mentioned before - I was just saying if one wanted to - he could with that stuff.
