Rear Axle swap?
Dust
Rear Axle swap?
Post by Dust »
How much difference in width is there between the 87 rear axle and a 79 Bronco 9"?
I'm guessing an inch or two?
Thanks!
Polarcub
Re: Rear Axle swap?
Post by Polarcub »
I believe its the same or awfully close (less than an inch).
Jeremy
Dust
Re: Rear Axle swap?
Post by Dust »
Polarcub wrote:I believe its the same or awfully close (less than an inch).
Wow, I guessed wrong.
Good I have a Pile of 9" axles, so that decision is made.
Re: Rear Axle swap?
73+ truck 9" axles and 78+ 9" Bronco axles should be 65" wms/wms
85+ 8.8 truck axles should also be 65" wms/wms
Van and 3/4 + 1 ton should be wider at 68" wms/wms
A 9" from an earlier truck is bolt it. My 9" rear end is from a 82.
