Timing & Spout questions
I need to time my bronco. The under the hood sticker calls for the timing to be 10 degrees btdc, but it tells me to pull the spout plug, and even though I pulled the motor, I don't have a clue where it is. Can someone explain the timing procedure and where I need to look for the spout connector.
- Phoenix0783
Re: spout connector
what year is your bronco? the spout is near the distributor up through '91 and by the cruise control after that. the connector is just a jumper for two wires that you unplug and that stops the computer from changing the timing. unplug it and set the timing to 10 degrees.
Re: spout connector
Its a '92. Where abouts is that located? Do you have a picture?
- Phoenix0783
Re: spout connector
Thank you very much. This is the last thing keeping me from finishing the motor!
Re: spout connector
It is within a few inches of the fender well mounted TFI module. Please ignore my zip tie skills. My finger is on it in the picture.
Re: spout connector
Thank you Philo. That is on the driverside fender well correct?
Re: spout connector
Driver side fender well below the hood spring.hobbyturnedobsession wrote:Thank you Philo. That is on the driverside fender well correct?
- Phoenix0783
Re: spout connector
Re: spout connector
Yep, that's what it looks like before you hack up your truck.
Re: spout connector
Thank you both very much. The timing has been off and its been a pain in the a** trying to figure it out. Do you guys have any insight on timing? This is my first time as well.
Re: spout connector
UPDATE Just wanted to thank you guys for the info. Timing it was a breeze even with the stalling issues I'm messing with. Only took me 5 min to time.
- kahuna bill
- Bronco Info: auto fab lift, 90 body on 91 frame, e40d, performer heads,jba headers, K&N intake
what distributor timing r u running?
did a search on GFB and didn't find a whole lot on what people are running as far as timing for thier 351w efi broncos. also went searching through the factory truck shop manual and it told me to go look in the engine/emissions manual, which i don't have.
anyways, i marked my rotor and distributor housing before i removed the distributor (removing intake manifolds for deep clean) so i'm not up a creek without a paddle if i don't know what others are running when i re-install the distributor... i'm more curious than anything.
So, what are y'all running for timing on ur 5.8l efi broncos?
Re: what distributor timing r u running?
10 DEGREES BTDC Thats stock I believe. Just make sure your rotor is turned toward the #1 cylinder.
I can't remember exactly what I'm running. somewhere between 10-12.
- BajaF250
- Bronco Info: 1982 Ford F250
I'm running 10°
- kahuna bill
cool. thanks for the info guys. sounds like 10 is a good round number. i'm re-installing the intake and manifold today as well as the distributor, i'll let ya know how it goes. before and after pics too.
thanks again.
thanks again.
- kahuna bill
picts of the change out are up... under "two years and counting" on the rides side of the forum
where do you set your timing
The book calls for 10 degrees before to TDC . What's yours set at ? Should I advance it a bit or leave it. I have been told 5 or 6 T D C is ideal.
