Hey guys,
Back from 5 weeks in India, how I miss the good ol USA !
My tranny guy didnt install my rear 4.56 gears because of clearence issues. Does this sound right ? I had installed 4.56 in 2001 F-150 many years ago with no issuess (different rearend i know)
His e-mail to me...
"The housing is too small to accomadate the gears you want. as it sits now we've got a 1/4 clearance top and bottom. You currently have a ratio of 3:55 Non posi. Biggest ratio based on housing dimension would be a 3:73 and would suggest a limited slip carrier."
Does this sound right ? I see 4wheelparts carries gears that fit into a 8.8 rear end.
thanks
Stock 8.8 housing clearence
- bajascott
- My belly is my best friend
Re: Stock 8.8 housing clearence
Seems lazy, I had 4:88 in an 8.8 and I know you can fit 5:14 in there as well with some clearancing.
- Bronco Info: 1995, Pre-runner S&S Fab kit, 35" Generals Grabbers
thats what I thought.... just making sure i wasnt off basis before I called him.
thanks
thanks
- Bronco Info: 94 centurion bronco 5.8/zf many mods more all the time.
Yeah seams lazy. You cant go off of clearance of the 3.55 because it isnt whats going in. 8.8 gears specific to the 8.8 will fit or they wouldnt sell them. Ive also seen 4.88's in an 8.8. Tell him also 4.10's came stock in some so hes way off with the 3.73 info. If it were me i would take it to a rear end/ driveline specific shop where thats all they do.
Did 1995 8.8 come with limited slip ?
Any axle code with a letter before the number is LS. Any axle code that is just numbers is open.
