Anyone running gt40p heads?
- Bronco Info: 95 351 ZF5 Dana 60s
Anybody out there running these crazy things? I have a set thats going on my project 5.8 and am wondering if anybody had header input that hasn't been discussed already. I've read every p-header thread known to man and it seems like everybody is stuck on the ford racing headers...too bad they're discontinued. I might just buy a set of JBAs and see how much fab they need.
I'm ok with building my own but then there's the carb legal issue.
thoughts?
thoughts?
Re: Anyone running gt40p heads?
The only thing you need to be smog legal is an o2 bung close too factory lo nation.you can order them from summit or jegs like 8 bucks
- ESHALLBETTER
I have GT40P heads on the 302 in my early bronco. I am running a JBA header from a the non GT40P motors. I had to heat and massage one spot on the header to clear a sparkplug, and I run a 1/2" thick header spacer on the drivers side. I have a season of wheeling now with no issues.
Actually my O2s are in my ypipe, I need that funky egr connercor on the pass side. To pass visual I need an EO number or to get it inspected by the BAR. I hate this state!greaslife wrote:The only thing you need to be smog legal is an o2 bung close too factory lo nation.you can order them from summit or jegs like 8 bucks
Thanks, good to know. Those are shorties right?ESHALLBETTER wrote:I have GT40P heads on the 302 in my early bronco. I am running a JBA header from a the non GT40P motors. I had to heat and massage one spot on the header to clear a sparkplug, and I run a 1/2" thick header spacer on the drivers side. I have a season of wheeling now with no issues.
- ESHALLBETTER
Yessir, the JBA shorties.
Nope. Headers have to be clearly labeled with the part # & you need documentation showing that the part is C.A.R.B. certified.greaslife wrote:The only thing you need to be smog legal is an o2 bung close too factory lo nation.you can order them from summit or jegs like 8 bucks
[quote="SteveG"[/quote]
Nope. Headers have to be clearly labeled with the part # & you need documentation showing that the part is C.A.R.B. certified.[/quote]
It depends on your smog guy I was able too get smoged this way
Greaslife you built your own headers?
Nope. Headers have to be clearly labeled with the part # & you need documentation showing that the part is C.A.R.B. certified.[/quote]greaslife wrote:[quote="SteveG"
It depends on your smog guy I was able too get smoged this way[/quote]
Ahhh. Well, finding someone that will do a crooked smog and having a smog legal aftermarket part are two completely different things. Personally, I wouldn't gamble on the hopes of finding someone that won't fail you for non-compliant parts. If you guys want to, that's fine but we don't need to promote illegal activity on GFB.
You are corect it not the right way of doing things.
- ESHALLBETTER
I may not have ANY desert in my neck of the woods, but I also don't have smog....that sounds horrible.
Smog's a joke. I think it's a good idea in theory but California has turned it into another money-making scam.
Thats wierd. I've taken my bronco to three different smog shops and not one of them said a word. My headers nor my intake have a serial number but I did drill a hole in the #1 exhaust tube and welded up the bung. It's legit just no carb number.
Well I'm sure all the shiny new parts and the candy paint will raise a few questions with this motor when it's done. All the smog techs in my area seem to know the rules pretty well.
- Deleted Account
What year is your bronco?
Mark Kiefer
Southwest Performance
858-449-2292
Pics
858-449-2292
Pics
