Dash Removal 80's
- poolman
- Bronco Info: 84 Bronco,Body off reconstruction. Auto Fab suspension,mix of 84-96 parts.
Dash Removal 80's
I want to remove my dash as a whole unit. I want to put it in another Bronco any tricks or tips, links? Thanks pm
94 Bronco roller for parts
91 F150 4x4for parts
96 Bronco for parts
84 Bronco for 351W
96 Bronco for parts
84 Bronco for 351W
- Rednek Renegade
Re: Dash Removal 80's
Be very patient and do not allow yourself to have a pair of dykes handy otherwise frustration will show its ugly head. Also be very gentle and dont force anything. 20 year old plastic dont respond well to prybars either.
Project el cheap-o
- poolman
I got it out! I have no doors,hood fenders,etc. on right now so that may have helped a lot. Pretty much took off dash pad and gage cluster face. 8 bolts, two on each lower corner and a couple around top speaker area.I had to cut one thing, the gear indicator and it was messed up anyways.I got the thing out as a unit much like they do when they install them at the factory. I'll get some pictures up later.
96 Bronco for parts
84 Bronco for 351W
96 Bronco for parts
84 Bronco for 351W
I did this on my 86 and i just destroyed it! But I wanted to upgrade to the 1993+ dash anyway! Still it was a lot of work so congrats on getting out in one piece.
- miesk5
- Bronco Info: 96 Bronco, E4OD, Man Xfer Case & Hubs
yo gang, here a coupla swaps;
Installation, Custom KWS in an 87
Source: by Chris P (Maximum) at http://www.abysmal.com/bronco/dash/dashboard.html
Installation pic from a 93 Bronco in an 81
Source: by PwrStnd at http://www.superford.org/registry/vehic ... 46#content
Installation pics from an 04 F-150 Supercrew in a 78
Source: by Quint C (Quints Bronco Project, (04 F-150 Supercrew drivetrain)
http://home.comcast.net/~qcrispin/bronco/
Dakota Digital Dash Installation in a 73-79
Source: by Trent (Picador, a Four Door 79, InfoFord) at http://www.ncspecialties.com/autobody/d ... /index.htm
Aluminum, Custom Fabrication Info & pics in a 78
Source: by HD78bronco (Brian B) at http://www.cb4x4.com/forums/showthread.php?t=374
Aluminum, Custom, Fabrication & Installation in a 78
Source: by Mike S, (Broncster, BRONKSTER) at http://www.supermotors.net/vehicles/registry/7387/63566
Aluminum, Custom, pics in a 90
Source: by Cam C (BlancoBronco, Project BLANCO) at http://www.supermotors.net/vehicles/registry/5331/57698
a product;
Aluminum, Custom, pic in a 95
Source: by stewartsraceworks.com via web.archive.org
http://web.archive.org/web/200512020319 ... ronco2.jpg
Fiberglass & Carbon Fiber Dash/Instrument Panel pics (a product)
Source: by mcneilracinginc.com
http://www.mcneilracinginc.com/off-road ... /index.htm#
This is what Steve83 did to his
83; The rear seat & dash are the original '83 parts, but the instrument cluster has been heavily modified with '88 fuel & volt gauges and a '94 PSOM.
http://www.supermotors.net/registry/2742/69150
a product;
See our Big Bronco Technical, Parts Sources & Technical Service Bulletins Links site @ broncolinks.com
THANKS to ALL WHO SERVE
