My new c&t beams just arrived and I am planning on finally lifting my truck this weekend. I have everything figured out except the steering.
I can't decide between flipping the TRE's to the top or getting a drop pitman arm. I searched but didn't see anything spelling out the pro's and con's of each.
So if anyone has some advice throw it out there.
Tie rod flip vs extended pitman arm
Re: Tie rod flip vs extended pitman arm
You don't need either unless your using drop down brackets. Factory pivots = factory steering.campbbg wrote:My new c&t beams just arrived and I am planning on finally lifting my truck this weekend. I have everything figured out except the steering.
- Bronco Info: 1990 Bronco EB
I second that Philo, Its not just flipping them either, from what I am told its a good amount of work.
I got it now I must have missed it somewhere that it was only needed for brackets. Thanks for the help guys.
