Battery light on???
- Bronco Info: 1990 Bronco EB
Battery light on???
ok heres the story.
Have had the Batt light on intermitently for a while with no issues.
I pulled the ALT and had it tested twice it came back fine.
I replace the battery with a new Interstate.
now it seems like it only charges part of the time.
the guage will be down and then spike high? Voltage Regulator?
Will having it scanned tell me anything?
Re: Battery light on???
Check your grounds body, chassis, engine block. All the stock grounds on my truck are wearing out volt gauge jumps around
ye I thought of that but would that really cause voltage spikes, Theres like 8 grounds.... what the hell It wont hurt to check...billy1911 wrote:Check your grounds body, chassis, engine block. All the stock grounds on my truck are wearing out volt gauge jumps around
Bad connection somewhere. Possible bad voltage regulator if the truck is equipped with one. Check the grounds and positive cables first.
Im being told by Vatozone that the Regulator is in The ALT.philofab wrote:Bad connection somewhere. Possible bad voltage regulator if the truck is equipped with one. Check the grounds and positive cables first.
So I checked the POS and Ground, replaced the lugs to the battery, pulled the alt again and had it checked a third time, and it still goes dead after driving it. I am thinking of just installing a new alt and cables, The Battery is new.
anyone got a spare alternator that I can test out?
Dezertbronco wrote:So I checked the POS and Ground, replaced the lugs to the battery, pulled the alt again and had it checked a third time, and it still goes dead after driving it. I am thinking of just installing a new alt and cables, The Battery is new.
Check the ground that goes from the battery to the fender... that one gave me problems a few months back.
I popped a volt reg on the way to the 500 last year in an F150. It blew the radio, race radio(kenwood 100watter), head lights, turn signals, ignition control module, coil, and tail lights and anything else that happened to be on. I dont understand why the fuses didnt pop.
I carry a spare alt in my bronco...im in san dimas. You are free to come toss it in to try.
What year Bronco is this?
Philo its a 90 w 351.
Chris Im @ vatozone now, I will just return it if its no good.
Check for continuity from the big lug on the alt to the battery positive. The fusible link could be damaged. Also check for +12 with the ignition on to the small plug, as this is the voltage sense line for the regulator.
UPDATE.
It was the voltage regulator $ 21 bucks and its like a whole new truck.
It must have taken a drink on last years mojave road trip.
I will be buying a Spare ASAP.
