Door Panels
Door Panels
Will an 87-91 door panel fit a 92-96 bronco?
- bajascott
- My belly is my best friend
Re: Door Panels
the deferost vents wont line up at the wing window
Re: Door Panels
Is it alterable by any chance?
- bajascott
Re: Door Panels
dont know. havent looked at a later model interior for while. they will go on,but you'll have a gap between the panel and the dash
Re: Door Panels
That doesn't bother me so much. They dont sell replacements....
- bajascott
Re: Door Panels
what color are you looking for?
i have some grey ish ones.... i think they are grey,or blue not sure haha
Re: Door Panels
Hahah, black ones sadly..... Gray would work though. They in good condition?
- bajascott
Re: Door Panels
not too bad of shape, i'll go out tomorrow and snap a pic or 2 for ya.
- Bronco Info: Wishing I had one!
Re: Door Panels
To swap in 92-96 panels I found these:
"The 92 and up F150 Has Different vent window ( squared off ) And door panel
turns up to cover difference. You would have to swap vent windows, possibly
arm rest mounts and switches (don't know if plug into your harness or not ). Also run extra wires for door lights but thats easy. I've done it, but truck didn't have PW."
"Vent windows have to be swapped, too. The new panel overhangs the front corners, so you have to get '92-96 vents. Since your truck uses the short weatherbelts and short glass, you don't have to remove the plastic spacer behind the glass run or swap weatherbelts, but I did.
You'll probably also have to move the armrest bracket to match the new panels, but I can't tell exactly where. I took a few guesses and eventually got it right."
