wheel bearings?
- Andy Jones
- Bronco Info: In the Works!
wheel bearings?
why does every wheel bearing, and seal i pick up from the auto parts store not fit
i have a 95 xlt fullsize Bronco! am i missing something here!!
Re: wheel bearings?
Which wheel bearings? Front? Rear? Inner or outer?
- Andy Jones
Re: wheel bearings?
All front... inner, outer, and seal. the seals dont fit in the hubs for the inner. And the inner and outer bearings dont fit on the spindals.philofab wrote:Which wheel bearings? Front? Rear? Inner or outer?
Re: wheel bearings?
Pictures of your knuckles/spindles please.
- Andy Jones
Re: wheel bearings?
Inner wheel seal that i pulled off the hub is on the left. all the wheel seal's that the auto parts stores keep pulling for a 1995 Bronco are on the right..
I know im not Crazy! heres the manufacturing year!
- Andy Jones
Re: wheel bearings?
I was just doing some interweb searching. and i think the parts on my Bronco are in the 1996 category.
- Andy Jones
Re: wheel bearings?
ok so i pulled the part numbers off my wheel bearings. they are Timken lm603049 inner and Timken lm501349 outer. the internet store that i looked them up on says they are not for a ford Bronco WTF!! and the Autozone down the road keeps giving me the wrong shit!
- Polarcub
Re: wheel bearings?
Andy I ran into a similiar problem not with the bearings themselves but the seals. I have 96 seals and 95 bearings I wil go check my boxes for part numbers for you
Okay I have Timken Set 45 LM501349-LM50130 200604 22, Set 37 LM603049-LM603011 200609 22 for bearings and the seal is also Timken 4250...For the bearings I gave you all the numbers on the box in order I am not exactly sure which is the actual part number hope it helps.
Jeremy
Re: wheel bearings?
You have 96 spindles and knuckles.
Re: wheel bearings?
Autozone is a crappy parts store.
- johncharlesb
Re: wheel bearings?
I concur. NAPA or the dealer are usually about the same price and the parts are much better.philofab wrote:Autozone is a crappy parts store.
Re: wheel bearings?
I had some issues with replacing the bearings on my '96 as well. It was strange.
About the only thing I get from autozone is Timken bearings
