So i am going to have a set of front beams lengthened and am having the axles done as well. Since I mainly use my Bronco on the road and rarely use 4 wheel drive i am going to take out front axles. My question is that when i pull the axles, will the stub axle that is left have any impact on driving? Can I leave it in or is it necessary to pull it?
Thanks
Pulling front axles on DD, ok to drive with stub axles?
- TrevorPiggott
Be nice to me, I'm learning....and slow in the head...
Re: Pulling front axles on DD, ok to drive with stub axles?
You have a choice of running a stub by itself or just putting a freeze plug in the backside of the spindle. You just need something in there to keep the grease in and water + dirt out.TrevorPiggott wrote:So i am going to have a set of front beams lengthened and am having the axles done as well. Since I mainly use my Bronco on the road and rarely use 4 wheel drive i am going to take out front axles. My question is that when i pull the axles, will the stub axle that is left have any impact on driving? Can I leave it in or is it necessary to pull it?
Thanks
- KBL
- Bronco Info: Working on a '73 F-100 with a TTB conversion
You'll also want to leave the third member in the driver's side beam. You'll lose strength if you take it out.
www.off-roadweb.com
