im getting ready to ditch the EFI
any advice
recommendations
check lists
requirements
1990 ford bronco
- Bronco Info: 90 xlt 6"lift deavers and procomps 35" tires 4:10 gears 5.0
Re: 1990 ford bronco
I am putting together a Terminator x MPFI system with a Edlebrock Super Victor MPFI 4150 intake and Edlebrock Victor EFI throttle body. I want to keep the 351w low enough to fit underneath a 72 Bronco hood. I plan to run a low profile plenum and a 1969 Mach 1 hood scoop.
I was just looking into Injectors and will probably go with Bosch high impedance gen 3 Injectors. Since I will be running the Fox body system, I am going with a dual sync distributor by Holley, so I don't have to worry as much about EMI caused buy an OEM front distributor.
That is my solution to the stock EFI system. Since my Bronco is a 72, I don't have to worry about smog checks.
David
David
