Bolt on housing
TexasBronco
Bronco Info: 92 Eddie Bauer 302 for now
Bolt on housing
Post by TexasBronco »
I’ve found a few bolt on front housings but, can’t find the inner stub axle. Does anyone have some or know where to find them. Also, has anyone tried to adapt a C clip stub axle into a bolt on housing?
Re: Bolt on housing
I'm sure there is a way to modify the C-clip housings to hold the stub axle in but I've not heard anyone who's really done the work to get the work figured out.
Re: Bolt on housing
I think it would not be to difficult to fabricate a bearing retainer and tap some holes in the case.
As for stub axles, you can get them from Dutchman and bearing's through Dana I think. Or find a aftermarket equivalent. If you are converting a c clip housing, you can find a press on version like a semi floater bearing for the 9".
If someone took the time to do it, that could be a good part for selling.
That is something I would like to put in my catalog of parts one day when I get my fabrication side of Wright Racing going. A 9" 40 spline TTB front end is another one I want to do.
David Wright
ntsqd
Re: Bolt on housing
Post by ntsqd »
I just recently talked to Dutchman about buying a whole axle set and they can't supply it. They don't make the RS stub and slip-yoke. Something about they couldn't make the part any stronger than stock due to some geometry constraints.
Anyone know a good source for these inner RS parts?
