How often do you change bushings and Heims?
Stan the Man
Post by Stan the Man »
I’ve had my Solo Stage 4 kit for about 3 years (maybe 30k miles with about 20 off road trips) and am wondering what’s the general life or maintenance interval of pivot bushings, leaf pack and hanger bushings, and radius arm heims?
How about coilovers? Im noticing I’m starting to sage passenger side about 1.5” front and back compared to driver side.
mobil1syn
Re: How often do you change bushings and Heims?
Post by mobil1syn »
Stan the Man wrote:
Thu Dec 17, 2020 10:04 pm
when was the last time you check the pressure in your shocks?
Stan the Man
mobil1syn wrote:
Fri Dec 18, 2020 9:54 am
Not since install. What should they be at?
Stan the Man
Not since install. What should be be at? King 2.5s.
biggiek
Bronco Info: 92 Ford Bronco
Post by biggiek »
If you havent checked anything this seems like a good time to do it. There are some tutorials on hiems regarding validating condition. Any vibration noises etc? I would check it all, validate torque on it all and go have fun.
Stan the Man
Okay thanks. I have a significant vibration above 65 mph, and have ruled out tires and driveshaft.
mobil1syn
Post by mobil1syn »
200psi fully extended
Stan the Man wrote:
Fri Dec 18, 2020 2:34 pm
Check to make sure your front hubs are properly unlocked. I've had experience with a simmilar problem a while ago and it turned out to be a stuck front hub. Spinning one front driveshaft can cause vibration at highway speeds.
Stan the Man
AussieRod wrote:
Fri Dec 25, 2020 7:01 pm
Thanks I’ll check that out.
